Vijeo designer V6
Ferino
Nov 2013
Metz
Hello I am a New member..
I am searching for a simple tutorial to start Vijeo designer V6..
What means the adress 30001 or 40001?
What are the equivalents of this adress (INT , WORD ...)?
How can I use this adress if I want to make a program on Unity Pro M?
You have tutorials all over internet, just use Google.
30001 and 40001 are Modbus addresses. 30001 for input registers and 40001 for holding registers. This addresses represent memory locations, so they can be INT, WORD... they can be even DWORD, but then they will take two addresses (40001 and 40002 for example).
Unity and Vijeo are totally compatible, so you can import your Unity project to Vijeo and use addresses like %Q0.0.1 or similar.
If you are using a schneider plc you can specify in the equiptment drive to use IEC adressing. Then you can use the plc address directly (%mw or %M)
Hello.. thanks to goghie and chud. Your answers were simple and clear.. it really help me to solve my problems.. Maybe you know Intouch software and i will ask you many others questions about it.
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
207
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
203
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
1,016
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,336
Hey all, I am using Vijeo Designer v6.2.8.12 for a mineral plant project. For that, I needed to incorporate three different plants' HMI page in...
1,210
