Vijeo Desiner
rahimi
Sep 2013
Tehran
Hello
Does everyone know about logging data in vijeo designer? It seemed to use just a simple script "flushToStorageboolean VariableName.flushToStorage();". But it does not work.
Also how can i retrieve these data?
Thank you so much
Just use the data logging (Logging group1) and specify where u want to save the data. Either to cf card or usb memory stick (Be sure to use schneider cf card and not a third party). The logged data can either be displayed on the screen via the historical trend, or you can upload the data from the memory using the Vijeo designer data manager tool installed with the software. This will suck of the data into a csv file
Thank you so much for your help Chud. It is really helpful.
It means that it is not necessary to write script for it?
where should I mention the location?
specify sram. This will be the usb or cf card. You can also just use the help and search for data logging. Will explain everything there
The difficulty is when one variable should be logged for about one year. then the sram cannot handle to save it completely. it should be saved on the cfcard
You can create multiple logging groups. One could be to the CF card for longer term logging, while another could be setup for faster short term logging
You do not need to use any scripting to log data.
On the 'Data Logging' branch of the tree (see Chud's screenshot) right click and select 'New Logging Group'
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
68
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
214
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
206
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
490
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,689
