VIPA 015-CEFPR01 - Profinet comunication
NoName
Sep 2003
Domžale
273
Hello all.
I am working in TIA Portal V15 with the following CPU from VIPA:
VIPA 015-CEFPR01
I configured the this CPU as a CPU 315-2 PN/DP + CP 343-1 in the hardware configuration and I added a profinet node(a Kolmorgne servo drive) to the configuration.
The configuration seems to be OK because there is no bus error and in Online view both the CPU and the profinet node are visible.
The problem is that the data exchange between the CPU and the profinet node doesn't work. Everything is 0 at the addresses where the status words should be.
Has anyone worked with this CPU before and can give me a hint what could be wrong with the configuration.
I tried to connect the same drive to a S7-1200 PLC and the communication there works fine. I get the drives status words and can control the drive with the PLC.
Cheers
Aleix
Hello. Which address do you mean? The IP address or the address of the configured telegram (I: 272 to 281, Q:272 to 291)?
If I check these I addresses everything is 0 which it shouldn't be.
Cheers.
Aleix
I created a 315-2PN/DP in TIA and the default process image size is 128 bytes. Either extend the process image size to incorporate the addresses you have configured or change the configured addresses to fall inside the process image.
Hello.
Thank you very much. I changed this and now I see the input-output data.
Another thing learnt.
Cheers
Aliex
hello , i have a task at my hand here and i am not sure why cant i find any manuals for the communication between the VIPA CPU015 and the VIPA HMI...
2,242
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
276
Hi guys, I have VIPA MCC 953-1LK00 1 MB, but it is blank. Does anybody have image for this card? Thx in advance.
811
Hello Friends I need to monitor a PLC Vipa. Which software and cable do i need? The upload will have the comments? Thanks in advance.
1,540
