Vm30 Pep Modular Computer
Did you really search ? Use your favorite internet browser... !
PEP Modular Computer is a german manufacturer of industrial systems (CPU, I/O, networking, storage units...) available on several standard platforms (VME, PCI, compact PCI...). They make part now of the Kontron group for a few years.
The VM30 you're talking about is a rackable CPU board, based on 68020/68881 processors, in 3U VME design. It's a quite old version,
but really interesting for all automation projects. Can be run with various multi-tasking real-time OS (OS-9 usually provided in basic cases). To be compared to actual VM42 and VM62 (up to 68060 processor) or other single-board VSBC units.
PLC-like projects can be written with IEC61131-3 platform-independent softwares (IsaGraf is a good one for example, but many others exist, depending on your kind of project).
Regards
Regards
Hi Laurent,
Do you know where I could get a few spare VM30 cards.
We are trying to extend the life of our existing VME system, which has PEP modular computers VM30 CPU Part# 544-001 (VM 30 – CPU for VME bus, 68EC030 25 MHZ CPU, 256K SRAM), which is no longer available as per Kontron AG (owner of PEP).
Thanks Jeremy
Hello, We are trying to extend the life of our existing VME system, which has PEP modular computers VM30 CPU Part# 544-001 (VM 30 – CPU for VME...
2,630
Hi all Now i'm using redlion as device to map I/O from PEP plc (Smart Base) In the communications, i used RS-232 Comms Port - ICP DAS - DCON...
2,204
dear all, i just wanted clarification and info's abt PEP's technical {advantages} and {disadvantages}, wt makes it different than others like...
1,900
Hello All. Im am in need of graphic cards for pep(VM30) The card is called VGPM, and the critical components is the graphical processors and the...
2,555
Dear All Is there anyone that used PEP, Smart IO, and used The ISAGraph software for programming PLC...... if there anyone, it would be great so...
3,117
