PLC Pie Guy
Hello all. I have another question coming from VMWare if anybody cares to take a moment. I created a VM using converter from my host machine, WIN7 PRO 64 bit. VM works fine but it is asking me to defrag the drive. So I shut down the VM and go to the VM settings for this particular VM in my workstation environment. I select the hard disk to be defrag but as soon as it starts it comes back with an error message from workstation thet "Deframentation failed: Not enough space on the file system for the selected operation." Now I am left wondering what this message means. I have 2 GB of memory selected for this VM. I have tried selecting up to 8 GB but I get the same error. For my Capacity I have current size = 4.7GB, System Free = 10.2 GB, Max size = 66.8 GB. Disk information says "Disk space is not preallocated for this hard disk. And Hard disk contents are stored in a single file". I am trying to defrag in this manner because it is what VMWare recommended me to do. Should I be trying to defrag the VM from inside the VM like you would normally defrag a drive? Or is doing it from the settings/utilities the right way to do it but with the VM running? I have used VMWare a bit but not enough to know what to do in some cases like this. Any advice will be gladly appreciated.
