VNC Service Question
HunterM93
May 2019
Arkansas
20
Is there a VNC type service that could be used to go through a plc network to remote into a PC?
Basically:
- From programming Computer connected to slot 8 1756-EN2T
-> Out slot 9 1756-EN2T to plant network hub
-> From plant network hub to Slot 8 1756-EN2T on a machine PLC
-> Out slot 9 1756-EN2T on machine plc's local network
-> Into a Windows 11 PC running FactoryTalk View ME Station.
A slightly shorter version of this would be:
- From programming Computer connected to factory machine network wifi.
-> To Slot 8 1756-EN2T on a machine PLC
-> Into a window11 PC running FactoryTalk View ME Station.
All this is using AllenBradley PLC's.
Currently the way we do this is by hardwiring into the machine PLC local network @ the machine and run TightVNC to control the PC.
Eventually this system will be transitioning to a ThinClient but that isnt soon enough.
That's a great question !
ControlLogix backplanes do not route or manage non-CIP protocols, specifically to prevent and prohibit this sort of PC-based access via automation networks.
You could go online with a ControlLogix through the routes you describe, but not run VNC or HTTP or FTP or RDP or any other general purpose computer protocol.
If you need networks to connect together for non-CIP purposes, you need a router, NAT, VLANs, or other ordinary IP networking device.
Hi All I have just configured a new 2711P-T19C22DP - it needed firmware V12 which I (eventually) got installed, and got my application running. I...
182
Good morning Folks. I've been trying to get this to work but something isn't adding up. I have a basic system that consists of a private...
373
Scenario: This is for a system that has a PV800 user interface (connected to a Micro850 PLC) programmed with CCW. There are various control...
555
Good Morning, Was wondering what software you guys like for a VNC client. Primary use would be remote control of PanelView Plus 7, Panelview...
757
Hello, I am dealing with a AB PanelView 5510 device which needs to be accessible via VNC (local only, NO internet access!). To enable the VNC...
2,054
