Wago 750-301 with 750-402 4DI module
Plc_User
Dec 2005
Belgium
317
I have an installation with a Siemens S5 135U that has an IM308C profibus master card and a profibus slave Wago 750-301 that has several 750-402 4DI modules.
I want to convert the S5 to S7.
I have imported the Wago GSD files in my Step 7.
The problem is that under the 750-301 profibus slave in the catalog, I do not see the 4DI module 750-402. I can see the 750-402 under the 750-333 profibusslave, but from here I cannot drag the 750-402 to the 750-301.
Has anyone experience with a Wago profibusslave on a Siemens S7, that consists of a 750-301 slave module and 750-402 4di module?
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
99
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
135
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
393
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
356
Hi, I'm new to working with PLCs and I'm experiencing issues with my WAGO 750-8212 device. When I attempt to turn it on, the SYS LED (orange)...
928
