Wago 750-343
it is not simple but possible.
it depends on the type and number of inputs and outputs.
an analog input is one word
an digital input is one bit in a word.
see manual for a complete list and where to start.
it depends on the software you are using.
Is there a way to know the internal addresses of the inputs and outputs of a Step 7 plc by looking at the wiring location or lights on the WAGO...
2,940
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
104
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
140
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
421
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
368
