WAGO webvisu blank page
ogmor
Jul 2009
china
Hi Everyone!
I am using a WAGO 750-881 for a small project, and I wanted to have a web visu, done with Codesys 2.3.
The visu (PLC_VISU) works well in Codesys, but I get a blank page when i call the web visu in a browser. I did a "clear all" and loaded the program again, no improvement.
I read that WAGO has some problems with Java applet, is this why i can't see anything on the webpage? If it is the case, is there a solution to get it working?
Thank you very much in advance !
The Codesys 2.3 web visualisation is a Java app which requires the Java plugin in a browser. The underlying plugin model in the browser is deprecated. This has nothing to do with Wago or Codesys, this is a decision made by makers of browser software. You can still use it in a 32-bit Firefox version older than v52. Check the Mozilla website to see if you can still download such versions.
Most makers of browser software have deprecated the NPAPI plugin model, there may be some that still work. Search online to find if there is more.
Note that this is for PC based browsers. Java web visualisations will not run on smartphones or tablets.
Thank you very much for your answer, I tried on a 32bit version, and it works :)
Once again, thank you !
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
124
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
359
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
346
How do you set up a message block for a REMOTE IO unit? (using ethernet IP)?
597
