Wall Clock Time in AB Micro 850
nightline
Feb 2010
Prinsenbeek
425
Can anyone tell how to get the Wall Clock Time in a A-B Micro 850?
I've a program where every 8 hours ( every shift ) some data need to be moved, and counters reset.
Or will the RA_RTO timer accurate enough?
Jack
I know about the Rtc module, but al my plugin possitions are already in use. So I'm looking for an other way to get something like a wall-clock-time.
At the moment on my application (S7-1212C), the PLC/HMI are showing the correct time, i.e. the displayed time matches the time of the clock on the...
932
This old chestnut again... Our clocks (UK) went back an hour yesterday. Now the time displayed on the HMI is 1hr behind what it should be. In...
24
2,042
The PLC in question is a S7-1212C. The PLC will be transportable on a wheeled trolley and used wherever it's needed in the factory. I've been...
1,345
On the HMI-1200, the Wall clock date shows "1/4/1970". How can I correct this? Can't seem to find where this date is coming from or how to change...
927
Hello all. Would anyone have sample code that uses a wall clock to move the CTU.ACC to a another variable in the PLC after 24-hours has elapsed? I...
1,938
