Wall mount Modbus RTU touch screen, Residential use
amigo
Sep 2006
city
45
I am looking for a nice looking wall mount Touch screen HMI with Modbus RTU slave driver.
This is for residential use, it has to mount on the wall. 5"-7" will do.
PLC is the master and will read and write to the touch screen.
Panel mount would look too ugly I think.
Any one can point me to a manufacturer?
Wall Mount Touch Screen
Hi Amigo,
Beckhoff New Automation Technology has got some nice wall mount touch screen panels available. They have M6 thread available for wall fixing. You can see them at www.beckhoff.com
Good Luck! Hope this helps you. 🤾
Thanks for the replies.
I will check them out.
@rpoet,
I understand what you are saying, but in this particular application, touch screen needs to be a slave. The master is a webserver doing other things and needs to write to the touch screen and then read from it when user initiates certain sequences.
Thanks.
Two HMI touch screens that come to mind that support Modbus slave are:
1. Redlion G3 series
2. Unitronics all-in-one PLC/HMI combo
So, I'm in the process of designing a Training room where I will mount a lot of PLC hardware Old and New. Some will use Din rail and others will...
948
Been trying to find a 19 or 22 inch wide screen Integrated Touch Screen Thin Client Wall Mounted unit Not having much luck. Anyone using...
1,425
Banner had a totally enclosed, wall mount 24Vdc 200mA power supply that was ideal for many apps - wall mount flange or put a DIN rail adapter on...
5,945
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
272
Hello, I'm working on a laptop that needs FactoryTalk Activation Manager installed on it as a host along with a Hyper-V VM client on the same...
118
