Water Bottle Filler- Micro Logix 1100 Series A
zelfan90
Apr 2010
fairmont,wv
I have implemeted all aspects into my my program for a water bottle filler. I have a conveyor, clamp, and water valve that fills up the bottle for 10 sec. per botttle. I have it set up if there is no workpresent it shuts down but no alarm. How would i make it to where it just shuts off and an alarm is sounded. What would i tie that too?
welcome to the forum ...
is this a "real-world" machine - or a simulated learning exercise? ...
we'll be glad to help either way - but it's going to be a lot easier for you and for us if we know what we're dealing with ...
This is a learning exercise
I figured out most of it. At the end i have added a counter that counts to 10 so you know how many water bottles there are in increments of 10. Although i need it to cycle through 10 times and it only does it once. Should i add a jumper at the end or a subroutine. P.S. (Im using RSLOGIX)
102
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
701
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
772
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
2,016
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,298
