Way to Reset Momentum comm parameters before connecting
ganutenator
May 2002
kansas
1,440
I heard a rumhor that there was an un-documentated way to reset the communication parameters on a momentum controller to their default settings by jumpering two pins on one of the serial ports.
Has anyone heard of such a thing?
For example, what if someone sets up a XMIT instruction to use the one and only comm port? Theoretically you could never connect.
Since we are on the topic, is there an easy way to clear the memory?
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
100
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
41
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
369
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
94
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
104
