Weintek HMI to Compact Logix
oldnerd
Mar 2011
Al
94
Has anyone had any experience with weintek hmi to compact logix.
The HMI addresses are different, FFF = file, DDD = word and ddd = bit.
I have not ran into this one before and just wanted to know what I was going to be up against.
oldnerd
In System Parameters, Setup your device as Compactlogix Free tags choose serial or ethernet communications. After that you will see an import button appear which allows you to import your tags for usage. There is also a DataType Button which allows the setup of UDT if used.
Thanks found Free Tags and the Data Type Button. Guess I have gotten lazy and use to all the auto functions A/B does that you do not think about, until you have to go and manually do them.
It is a quick and easy process during development to export from Logix/Studio5000 and import into Easybuilder.
It is just a shame you can't import any UDT's you want to access. Perhaps one day....
If you do create any UDT's in the HMI, they are not "portable" between PCs, unless you allow decompilation of the EXOB file. I made the mistake of developing an HMI application on a desktop, then copied the project file to a laptop to take to site, where I had to re-enter the UDT structure.
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
579
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,375
I'm attaching an image. Ideally, I want to display a week worth of data on the hmi, but the max seconds I can enter for the x axis second display...
808
Having some fun with a system I’ve been asked to recode. The HMI is manufactured by Weintek (EasyBuilder Pro) and the PLC is an ABB PM573. Linked...
1,027
Hi; I have Weintek HMI MT8051XE at a machine. I want to play a customized alarm sound. I uploaded the alarm sound in project and downloaded to...
1,633
