Weintek to s7 314 imf error
Shoaib53563
Apr 2016
Lahore
In plc fc 6 block use time to s5time converter.
In weintek Hmi i use read/write input numeric
I use 32bit unsighned formate and connect plc then hmi not show any think.
I don't understand hmi adress format and plc min max range.
Try 16 bit unsigned. Min/Max range limits the operator from entering invalid numbers in the field. Leave it at the default of 0000 to 9999 until you get it working.
Now i set 16 bit formate. Then hmi connect to plc and write any number. Plc data register change this value.
But i check plc online .
Plc display time value in minuts instead of mili second
a "time" value won't display parts that are zero, e.g. t#12m0s0ms displays as t#12m.
if you put the variable in a VAT-table, change the "display format" to "DEC" and it shows in all miliseconds 12min -> (L#720000)
then.. converting to S5TIME means loss of information. you can't have 1 hour and 230 ms for instance.
s5time can be..:
0..999 * 10 ms (max 9s990ms; 10ms resolution)
0..999 * 100 ms (max 1m39s900ms; 100ms resolution)
0..999 * 1 s (max 16m39s0ms; 1s resolution)
0..999 * 10 s ( max 2H46M30S; 10 sec resolution)
you might want to use IEC timers (SFB4,5)
I change vat table formate s5time to dec.
No sucess to solve issue.
I am already use IEC fc40 .
Can you post a screenshot of your VAT table with both the TIME variable (set by HMI) and the S5TIME variable?
I'm still confused why you want to go to s5time if you can use IEC timer and use the TIME variable directly
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
190
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
575
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
369
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
934
Hi guys: I'm looking for, the programming software for Weintek MT8150iE, I looked for at Weintek Website, but , I can't find it help me please AD
1,369
