What am i doing wrong with rslinx?
Freires
Aug 2014
sao paulo
i have a plc ab 1400 with a module 1762-iq8 but rslinx cannt detect this module, only the plc. :confused:
there is a different way to detect the module and another to the plc in rslinx or automatically when i select ""rs232 df1 devices"" (configure devices in rslinx) and all parameters is ok must appear mi plc with my module??
i hope that you can understand me
Regards.
RSLinx will only detect the CPU (the Micrologix 1400 in your case). You will need to use RSLogix 500 to detect the additional I/O modules (using IO Confguration).
Regards,
Rob
Guys, Something I've got used to over the years but said I'll finally try and do something about it. Say I want to download/online to a CLX...
1,514
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
202
In Easy Builder Pro: Unexpected results... I've got a toggle switch set to trigger a macro to write a specified integer or a 0 depending on the...
2,322
I created default values for some new alarm setpoints. They are D361,D327,D329,D331 (see pic). When I put them into monitor mode, I was expecting...
23
5,253
I'm trying to configure an ethernet driver and when I browse sswho nothing shows up on the network. I have very little experience with...
4,899
