what does this exe in folder (programmfiles Siemens\WinCC\bin) do???
codemaker555
Jan 2010
india
Dear All can any one tell that the exe files in the folder path (Siemens\WinCC\bin) what is there exact application any document available ... irequest u to go through the attachment u will certanly come to know what i mean......... :oops: o_O
/bin folders contain all the programs associated with something.
After a bit of looking, I found the "WinCC options" manual on the siemens website, which says:
Important Settings within the WinCC System:
To make it possible to (acoustically) signal messages within the WinCC
system (by means of the audible indicator module) at specific operator
terminals, the signal module run -time module (HMRT.EXE) must be loaded
in the start up list of the client computer
Note:
The SBG RUNTIME module (HMRT.EXE) cannot be connected
within the start up list of the server computer. The
"Alarm
Logging Wizard"
is responsible for connecting the SBG
RUNTIME module in the start up list of each client computer.
The
"Alarm Logging Wizard" is located in the control center
under the
"Editor" "Base" data project components. While you
are editing the Alarm Logging wizard, activate the
"Connect
Audible Indicators"
check box to connect the audible indicators
functionality. You can find this check box in the
"Message
Window Configuration"
window.
Thank you sir but this is incomplete sir i would be very greatful to you if u can give some manual or some link ....which can give me full meaning and use of all those exes present there
Hello All I've posted my question on various wonderware specific forums with no luck. Thats why i'm posing this here. We want to install InTouch...
18
12,465
I am having a problem to move master license from USB pendrive E: drive to C using EvMoveCF.exe in Windows Virtual PC XP Mode. In EvMoveCF drop...
7,450
I have followed several links to this utility but they all point to obsolete pages. Does anyone have a good link? Or could someone post it here if...
6,313
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
44
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
