What is 1747-PIC
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day. Recently had EE retire and I inherited his "treasure's" that have been amassed over the years. One such item is a 1747-PIC (for AB SLC 500). I'm relatively new at this and want to know what this is used for. I looked at the AB material but wanted to get an idea as to its application, to see if I chuck this thing or keep it. Thank you
It is an electrical convertor from RS232 to RS485 as used with AB DH485 protocol. With it a PC with a REAL serial port (NOT a USB to RS232 interface) can use the DH485 protocol direct to the RJ45 program port of a SLC Brick, SLC 5/03 modular and the DH485 HMI units.
Good news you can use that to program your 5/03 if you tie up your serial port with that marquee.
It can also be used on SLC 5/01 and 5/02.
Don't toss it !
I keep one PC with a set of DOS software and the 15-20 year old interface technologies including the 1747-PIC. There are a handful of very old interfaces you just need those tools for.
If you don't maintain a legacy PC or have any very old SLC-500 controllers (fixed models or 5/01 and 5/02) you don't need this device. It's very hard to make the old DOS direct hardware driver work under Windows; we've been struggling with it since NT 4.0 and finally scrubbed the effort with Windows 7.
Don't toss it out, though; You should be able to get a 25% discount on a 1747-UIC if you trade in the old unit via the "Step Forward" program.
good afternoon all I had to pull out the old 1747-pic module my question it has a 25 pin connection I need to go to a 9 pin connection do pin 2...
1,599
Im getting trouble with my plc using 1747 pic connection, i found this solution: http://www.plctalk.net/qanda/archive/index.php/t-63919.html, but...
2,265
Working with dmroeder to get a AB PIC adapter to work under Windows using SP3 update. Installed his SP3 fix file and still can not get RSlinx to...
25
6,259
Hello everyone, I received a Fatal error message when added driver 1747-PIC, after that I closed that window and driver was added normally, but...
2,152
We are trying to connect to an Allen Bradley SLC 500 Processor 1747-L40A with a 1747-PIC box. PIC box to laptop connection is with 9-pin to...
4,059
