What is a solid bearing?
Tofo
May 2013
CA
57
When I design a machine, my boss mentioned that used a solid bearing on the motor shaft and "direct mount" to a shaft to drive motion.
I googled solid bearing. From the image search, the results are flange bearings. If solid bearing equal to flange bearing, then how to do a direct mount???
Please help
ask your boss as a lot of different approaches are possible here.
and dont mind i like it when being asked dumb questions as at that moment i like the conversation and your thinking.
Reasoning ?
You didn't mention horsepower or application. Do you or your boss have experience in drive-train design, bearings, and couplings ?
"Solid Bearing" covers a lot of territory. It can range from a simple grease lubricated bushing made from bronze, babbitt, or other metals. There are many non-metallic bearing materials as well. Other designs include pressure lubricated oil journal bearings, which are still widely used in large horsepower electric motors and large rotating machinery - not to mention automotive engines.
The collar is incidental - it is there to take axial thrust loads as opposed to the radial loads restrained by the bushing.
I don't think "solid bearing" is a commonly used term. "Bushing" or "journal" bearing are more typical names.
The opposite is the rolling element bearing - ball or roller being most common. These are sometimes referred to as "anti-friction" bearings, a term that annoys me. (After all, a "pro-friction" bearing would be a brake!)
Agreed, once a bearing goes from "anti-friction" to "pro-friction" it is generally time to put a new one in.
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,107
I have an Schneider M1E 171CBU98090 Processor adapter with only a solid red 'ERR' light lit. Manual explains flashing red ERR but not Solid with...
1,017
Hey guys, We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts) with the top open but we normally put a container...
1,557
I am using an Allen Bradley CompactLogix 1769-L18ERM-BB1B to control an Allen Bradley 700-H series relay with a 24VDC coil (see pic) The relay is...
898
Hi to All, How I can change NPN to PNP solid state switch? Exapmle1: D-M9N Solid state switch with D-M9P Exapmle2: or allen bradley p.e.c. type...
1,451
