What is the lowest version of Studio 5000 that a new CompactLogix can communicate
Aug 2016
Virginia
343
Good Evening ,
I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of Studio 5000 that would satisfy it running , successful ?
Thanks so much ,
CompactLogix PLC and RSlogix / Studio 5000 compatibility depends on which model CompactLogix you have. And it has got complicated now days.
Easiest way to confirm is to use the Rockwell Automation Product Compatibility & Download Center
https://compatibility.rockwellautomation.com/
Use the Compare Products link to select the CompactLogix PLC Model and the RSlogix / Studio 5000 Version.
Look for the green ticks to confirm compatibility for the combination
Good Evening ,
Thanks so much ,
This was from a bit back, but most likely a 5370 would work well with V28. V28 doesn't play well with anything newer.
5370 and 5570 processors (excluding some safety processors) can go all the way back to v20.
5380 and 5580 processors generally start somewhere around v30, but there are sometimes limitations with their functionality until you get to about v32.
Good Evening ,
Thanks so much ,
That version should suffice for any CompactLogix, generally.*
If you are current on licensing, hopping to v36 is an overall upgrade.
*Excluding the 5069 'P' models.
I am working with Allen-Bradley RSLogix 5000. I would like to track the highest and lowest values in an array set by a FFL instruction. Is there...
4,842
I would like to record the lowest hourly analog value and write it to a separate tag. It's for a temperature transmitter on a sludge dryer. Is...
3,684
This is a picture of a 60" LED TV running Windows 8.1 from a $129 PC. It has a 1.33Ghz quad core processor with 2Gb RAM, so it's not an extreme...
17
7,142
Good Morning , I would like to keep RS Logix 5000 has my primary PLC software package. I have many old standalone machines around that have...
3,452
PLC is a SLC 5/04 I can one write logic to see how high or how low a value got? Example their is a 0-10v scaled signal coming into my analog...
2,534
