What parameter must I change in a micromaster to increase motor speed
Johnbit89
May 2014
Nottingham
I have a micromaster 440 inverter connected to a motor. The motor runs at a constant speed but this is too slow. Is there a parameter I can change to increase or decrease the motor speed, and does this need to be saved?
Good Morning , I know it has been a lot of discussion about the Wall Clock in ControlLogix. I have been looking at the sample program, and...
6,153
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
294
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
76
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
444
Hi Everyone, I am trying to add a constant value (such as a string) into the parameter file. I put the string in " " but it does not work. would...
197
