what PLC code has .cxp, .opt, .onw extensions?
toutiao
Apr 2006
Albuquerque
I inherited some PLC code from a previous colleague and I can't open them with Mitsubishi QX-configurator.
The extensions are:
.cxp
.opt
.onw
Are these codes files for a different type of PLC? What type of PLC uses such extension? Omron?
Many thanks!
Toutiao
As Panic Mode said, Omron
The .cxp and .opt are the program files for Plc's, used with CX Programmer, the Omron plc programming software.
The .onw is the file extension for Omron HMI software called NTST
265
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
224
Hi All, I wanted some feedback/thoughts on code implementation or development across several offices. What has been your collaborative...
417
Hi! I'm fairly new to PLCs, and a PLC I was swapping sensors for shows the error code 497 - 0x050000 on the top of the HMI when I powered it back...
618
