what the mean of Assembly Instance in RSLogix5000
wendaiyu
Jun 2014
toronto
87
Hi, folks, how are you?
On our production line, we use AB RSLogix5000 as main PLC to control fanuc robots via ControlNet. So I checked the properties of controlnet module.
Could you tell me what the mean of Assembly Instance?
Thanks a lot.
Assembly instances are a code and data structure to allow communications to a device over CIP (Common Industrial Protocol). Each device generally supports 3 concurrent ones, an Input instance, an Output instance, and a Configuration instance. Some devices may support different interfaces for any or all of the three depending on the instance code.
As an example, maybe a drive can report back just its speed under one input instance, or 40 different values under another input instance.
For a thorough description, see the ODVA CIP Protocols Paper and look at Assembly Objects.
The picture attached relates to the properties for the F9 key. Does anyone know what 'object number' refers to? What does 'object number' mean...
732
I have used plenty of Fx 3U's but this is the first I have ever seen the ES-A. I can't find any refrence to it in any Mitsubishi literature. Looks...
2,345
When I do a search of used devices (typically, to find a spare one I can use), this table appears, but I don't understand what "unpaired" means or...
1,413
When I press F4 to convert the code, I get this message. What does it mean? Thanks
2,584
