What's Wrong with my Timer?
May 2015
Colorado
I am running a compactlogix processor on RSlogix 5000.
My timer is self resetting with the XIO Timer DN bit in the same rung. This is so the calculation is done at the desired programmed frequency.
On the following rung, when the XIC Timer DN bit is "true", it should initiate the calculation. What I am finding is that the calculation is only being done every 1/10 times that the timer finishes and the done bit is true. What is causing this to be inconsistent?
Here is a screenshot of the two rungs:
http://i.imgur.com/A6jKdtp.png
Also, what is interesting to me is I have three other subroutines on this project with the same exact logic, just different tags which perform the calculation correctly and consistently.
How have you verified that? In the picture the timer should trigger the update once every 10 seconds. Is it possible that you added 1 zero too many to the preset but you believe that it is set for 1 second?
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
208
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
107
Hi all, I am having an issue with FT View Studio ME when I try to open the propoerties of any object, the size of it is very big and doesn't let...
111
ewrong aka the censored brand of remote access this thing is kicking my butt and im not sure if i am just irritated enough that i am missing...
644
In Easy Builder Pro: Unexpected results... I've got a toggle switch set to trigger a macro to write a specified integer or a 0 depending on the...
2,326
