Which INI file to modify for DirectSoft32:
Aug 2003
71
Does anyone know which INI file I have to modify in order for DirectSoft32 to stop looking at the PROJECT folder every time I choose OPEN and instead look in MY DOCUMENTS folder?
Or better yet look at the same folder that was last opened.
Andy
When you open DirectSoft Launch, on the left is a listing for DS400.INI. Click on it and go down to the [PATHS] section. Modify the default directory there. I don't think it has a memory of "last opened directory"
Hi everybody, I'm just wondering if somebody had a same idea like me. I would like to make customized RSlogix environment like color convention...
3,471
Anyone using InTouch ever have this error? I am getting this error when I open my project in Window Maker. I click "ok" and the project opens...
6,675
Hello, i have a serious problem: i can't read .ini files especially win.ini from intouch 9.5 and store the string readed into a variable can you...
1,307
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
165
Is it possible to connect a PC to the mini console's RJ12 connector? use an RJ12/DB9 cable?
995
