Which RSlinx to use
ranjana
Aug 2002
22
I am planning to write my own VB program (simple one) to acquire data from AB SLC 500 which RSlinx should i have to buy.
RSlinx oem or professional or gateway . I have 3 nodes in DH+ .
Many thanks
Sly, you must own some shares in Rockwell Software. Why else would you want Ranjana to spend more money than he has to since RSLinx OEM does DDE just fine. We use it here to link to a production spreadsheet that is saved to our intranet for all to see. It has it's limitations, but it will work for Dynamic Data Exchange between one PC and a DH+ network.
Many thanks Vetteboy for the link. we are in process of placing a order to their DH+ driver.
Is there anyother similar software MFR with realy good HMI software with free runtimes.
I had used RSView for one of my application to study the pattern of outputs switching on and their on and off time with their RStrendX and trends from their library. but the update time was realy poor that on time and off time measured are not that reliable compared to our Hioki recorder. then we switched back to recorders. if you are aware about any of these software please let me know.
Also i was searching for a similar software from rockwell - RSrules. I could not find that software any more in RS website. is that software phased out. is there any other MFR for this software.
Many thanks
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
63
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
90
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
238
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
293
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
205
