Whole db Crc check ?
SHKODRAN
May 2010
Italy
102
Can anyone tell me how to monitor a db if the data changes?
I want to restore data from the store db to destination db only if the information does not match the source to the destination..
Can someone help me.
Note: Db is 100 byte only Dword data!
Thanks.
@ L D[AR2,P#0.0]
You're right, I can do a comparison of the two db, the problem is that I can not
do it cyclically.
Theoretically no one could write of db, since it is protected by dynamic password (HMI), but often the technicians provide the formula of password generation , then they also operators.
@TurpoUrpo
No , it is not a barrier , I understand you , but it is db of important machine parameters.
Thank you, and sorry for my English disastrous.
Thanks.
Add up the byte (or word) values to a double word containg the check sum. Compare with the check sum for the protected DB.
It is not 100% secure if more values are changed at the same instant, and the sum of the changes = 0.
Kalle
Here's the source to compare two DB's and correct one to the other and indicate when they are different:
Code:
FUNCTION FC 5 : BOOL
TITLE =if userDB <> MasterDB then userDB:=MasterDB
VERSION : 0.1
VAR_INPUT
  MasterDB : BLOCK_DB ;
  UserDB : BLOCK_DB ;
END_VAR
VAR_TEMP
  iloopCount : INT ;
END_VAR
BEGIN
NETWORK
TITLE =RET_VAL := userDB <> MasterDB
      SET   ;
      R     #RET_VAL;
      LAR1  P#DBX 0.0;
      LAR2  P#DIX 0.0;
      OPN   #MasterDB;
      CDB   ;
      OPN   #UserDB;
      L     DBLG;
A:    T     #iloopCount;
      L     B [AR1,P#0.0];
      L     B [AR2,P#0.0];
      ==I   ;
      JC    ok;
      S     #RET_VAL;
      T     B [AR1,P#0.0];
ok:   +AR1  P#1.0;
      +AR2  P#1.0;
      L     #iloopCount;
      LOOP  A;
      SET   ;
      SAVE  ;
END_FUNCTION
Not bad the idea of ​​LD [AR2, P # 0.0], I thought of doing something univesrsale for use with the Db-linked and unlinked, but it's better than nothing.
I will try to implement something more, thanks for the help
you are very helpful.
Hi, I have an issue with an S7 PLC when downloading over WiFi. It's a pretty big FB that I wanna download and the connection is poor. But it's...
2,356
Hi, all. I seemed to have hit a wall on my decimal to fraction forum. Therefore, anyone know how to separate a number like 17.33333 into 17 and...
4,059
Hey guys, I have a customer who wants to install a plant process network. Of course this is a large project and its barely in the development...
2,335
Hi, Does anyone know how to do this on an S5 115U PLC? It doesn't seem as straight forward as S7. For example, I want to move DB1 with 255...
1,321
Hi, I only know how to read one bit of e.g. an input port, using e.g. I0.7 or names from the standard table for such a single IO line. Is there...
4,692
