Wide-range speed control (VFD, etc.)
phuz
Jun 2008
Mohnton, PA
1,044
I need some help trying to pick a motor and controller (possibly VFD) for a winder application. It is going to use a foot-pedal input to control speed but the troubling part of this is the wide range of speed that they will run, which is 1-55rpm. We'll obviously need to incorporate a gearbox to get our motor to that range, but using an AC motor with a VFD means that we would have to run this at 1Hz some of the time, which would produce a bunch of heat. What are some other options out there (preferably AB) that wouldn't produce that kind of heat when running that slow?
With that wide of a speed range, you'll likely want a closed loop drive anyway. So, if it's small, a Servo Motor and drive would likely be cheaper and be TENV, so it doesn't much care what speed its running. If it's larger, just get a TEBC vector motor...
I think your low end hz will be determined by the gearbox ratio you use. 60 to 1 seems like it should bring you to between 20-30 Hz
I don't see the problem there
I have motors running at 0.5 hz and lower all the way to 120 hz on a standard vector duty motor.
I have motors running at 0 rpm holding full load no problem
Some Marathon 1800 rpm motor can be run at 5000 rpm right out of the box it's right on the name plate. I have had other motors high speed balances to over 7000 rpm.
I had one I inherited the vfd was running at 300hz output I calculated the motor speed at about 20,000 rpm
It's all in the selection of the drive and motor
I normally use Yaskawa Drives with Marathon Motors ever seen any problems
If you need help with a specific application pm me
+1 For the Marathon Motors. Any of their "BlackMax" series should work, they have 1000:1 constant torque range.
For example the Y535:Datasheet
+2 for BlackMax.
I've used them, driven by Indramat (I mean Bosch-Rexroth) servo drives, in "third party motor mode", with super success.
the pedal should have a log scale and not a linear one, this will improve the control.
as it is only 55 rpm you will need a gear box to get a better control.
so the control would be from 1 Hz up to 60 giving a speed from 1 to 60 rpm. even stall is not a big problem as long as you define the current correct.
Anyone else using Pi-Hole ? Had a spare Pi laying around a while ago and have been using this setup ever since. Browsing is not the same with out...
884
Good Morning , Not too familiar with Worldwide drives . I have a new WorldDrive Flex Control FC drive . The customer says it is 0-10 vdc and...
1,322
my customer has a full 1769-compactlogix rack. they want to remove the two cards in slot 5 and slot 6 and replace them with two new cards. The...
1,580
Management has decided they want a monitoring screen for every PLC and IO module in the plant. Also looking for a way to monitor when a PLC fails...
1,370
I have recently been tasked at a new job to integrate all the automated cells at our plant to have remote access to the production data (viewing...
18
5,500
