Will Linx and Red Lion Conflict
AlanSmith
Mar 2007
Ashbourne, Derbyshire
Hi. If a PC application, (for example Excel) is using RSLinx (DDE) to connect to a SLC505 and I then connect a Red Lion DSP unit to the same PLC, both via the same ethernet, then would I expect any kind of conflict between the two. I ask because I am considering adding the DSP to an existing system. The DSP would be used for some data logging, and as a Virtual HMI. The PC application is by someone else and I do not want to mess with it.
Thanks in advance for any replies... Alan
If those are the only connections, then no. There is a limit to the number of active connections to the SLC, but I don't remember the exact number (I think it is around 8).
The DSP should be able to connect and get the data out without interfering with Linx.
Does anyone have any experience in running RSLINX on Clustered Servers (2 physical Servers in High Availability Server Architecture)? RSLINX is...
837
Hi; I want to eliminate already configured driver in RS Linx Gateway (image attached). If i remove by a way, its again appears upon restarting...
2,084
I recently changed to a new laptop and still have access to the old files. Does anybody know the location of the file that stores the configured...
1,187
I have a 1756 L62 ControlLogix5562 controller I cannot connect to via ethernet. Get RSLinx cannot communicate message. Verision 19. It has a...
1,677
Currently i have my EB_ETH-1 driver setup with an ip for a gateway logix rack The gateway rack have multiple ENBT cads and so my linx config...
3,646
