win cc
mick1985
Feb 2014
Barnsley
Im new to wincc
Im currently working on a project in wincc v7.0. I need to be able to enter a value in a I/O field and multiply it by 1000 and then transfer the multiplied value to a tag in order to use it in my s7 program. Any ideas on how i would do this in a vbs action?
Thanks in advance
WinCC
Thanks for the reply
I have around 120 I/O fields in the project and thought it would be easier to do it in win cc rather than in the plc.
I would advise to do the maths inside the PLC. It will be much easier to edit in the future and also provide for easier scalability. The HMI itself isn't really designed to be doing calculations etc. You will probably find you can do the multiplication in one place in the PLC and then run each 'tag' through this function. That way if the maths changes in the future you're just changing it in one place. ;-)
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
60
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
200
Dear Friends, I have face a lot of problems using Panelview Plus 7 Series B with Win10 IO: I can not map a netwaork drive, when using file...
131
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
144
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
178
