Win911?
jgreenewv
Aug 2002
New Mexico, USA
242
Hello,
After using SCADAlarm on several WonderWare projects, I decided to try out Win911 on a Citect project I am currently working on. So far, I have had to download replacement modem drivers for the TAPI modem Win911 supplied. Now, Win911 will dial out on a few alarms (usually between two and six), then when it dials out, it won't play any messages. I am currently using Text-to-Speech, and the modem supplied is an AOpen PCI modem. This being my first experience with Win911, I'm not sure if this is going to be software or modem issues. I'm trying to get some opinions from current users before I get tied up with their tech support. Thanks.
Did you get the Telephony Card with your software? If I remember correctly you need that to do text to speech. But it has been a while since I used it.
In the Version 7 manual, it says the text-to-speech can be used with any supported TAPI modem. I wouldn't think that would be the problem, but to make sure, I may try to use WAV files instead of the text-to-speech and see if that makes any difference. :unsure:
Please note that TAPI voice modems are not reliable enough for telephony. My suggestion: use real telephony card (such as Dialogic/Intel). To read more please see the following link:
http://www.sunny-beach.net/modems/modemlist.htm
http://www.ivrsoft.com/voice-modems.htm
You may also try the U.C.ME-OPC alarm notification software from Control-See ( www.controlsee.com ). You may download a fully functional evaluation copy of U.C.ME-OPC.
Michael Meirovitz
Control-See Software Solutions Ltd.
HI im using win911 V7 and am having a problem with the voice cutting out part way through the call and it stops talking when a alarm is being...
68
We have a critical alarm system that uses Win-911 paging software that talks to an annunciator panel using a Modbus driver. The software runs on...
550
So View SE 10 was the last to support HMI alarm tags. View SE 11 says you must migrate them to Alarm and Events. The View SE alarm summary will...
1,898
At one site we just got the latest version of Win911 for producing notification email/text. This latest version is web based and all the...
2,155
anyone on here using WIN911 Alarm Notifier system with OPC-DA? general question to network with other users.
3,156
