WinCC connection to S7-300 fail
userxyz
May 2002
any
2,768
I have a PC with WinCC 7.4 and a PLC 315-2DP with 343-1 card. I cannot get connection to the PLC in the tag management while settings of the ethernet driver seem right...
Any idea what I overlooked ?
Thanks in advance,
Kind regards,
Combo
WinCC
Don't know why the attachements were not shown, but I got it online...
I think that placing an IO Field on a screen that requires updating did the connection, is that possible ? So a long you don't ask a tag, the connection could remain in 'not connected' status I think. I'm not sure about this, but that's the impression I got..
Kind regards,
Combo
I can't see your attachments, not sure why
Kind regards,
Combo
Sounds plausible, at the very least. I know WinCC tries to minimize tag access as possible, managing unused connections seems the next logical step.
Not sure about WinCC, but in WinCCFlex/TIA I usually just browse for a tag in the plc and drag it over, this creates the connection for me.
I can say for WinCC 7.3 that WinCC connects to the PLC at runtime start and holds the connection open, even if there is no tag under this connection.
At least it subscribes always to mode transition events like run/stop/warmstart in the PLC.
Hey Guys, I've connected a s7-300 CPU315-2DP with MPI interface to WinCC and can read a bit address like M50.0, But when I use TCP/IP interface...
5,959
Dear all, in wincc advanced RT (same as in wincc flexible), when connection to PLC is loss, output field (real) goes to ####. I suppose that tag...
158
Hello, I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller. using profinet to connect all 3...
3,033
Hi, I am working on a project in which, we have a requirement to connect multiple PLC's with WinCC scada. The scenario is that we have multi...
2,967
Hello, Since this morning I'm having an issue with a connection to a CPU from Proficy and WinCC. The connection is interrupting and connecting...
1,401
