WinCC Flex 2008 calculate after data entry - Faceplate
cjd1965
Apr 2007
UK
1,659
Hi
I have a faceplate where the user has to enter a time, in seconds. This raw entry is milliseconds and usually i would use the tag settings to linear scale it by a factor of 1000.
There are approx 12 entries on the faceplate that would need this.
Because i am using a data structure linked to a udt which is type time i was wondering how i could call a script to do this. I notice there is a input finished event.
Alternatively I could do some mods in the PLC code to do it
On possible way is to use internal faceplate tags for your input fields in the faceplate. Then "OnFinishInput" event you call the script in faceplate. In the script you can call all internal input values and do the calculation and the assign the values to the structure tags.
This only works one way. You cant change the values in the PLC and display them on the HMI. You can only enter values in the faceplate and write them to the PLC
Hi Bratt
I went with my original thoughts and changed the time to int then modified the PLC code to multiply by 1000. WinCC Faceplates seen slightly crippled
Cheers
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,126
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,687
Hi! I'm a little lost here. I have made a script in VB that run perfect when I simulate it on my programming machine (Windows 8.1) But when I...
2,793
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,248
hi guys,,can i personalize data logging in wincc flex? i mean i want to make a table that shows log data in a better platform than in wincc,,,i...
1,429
