WinCC Flex and "In-Sight Display Control" ActiveX
smcmanus
Jan 2006
Vancouver
109
Has anyone ever used the "Cognex In-Sight Display Control" ActiveX in a WinCC Flexible application? The exact name of the control is "cvsInsigtDisplay.ocx". It shows op in My Controls ToolBox but when I drag it to the screen it gives me errors.
Is your HMI a panel ? Or is it a PC RT ?
Dont count on that a panel can show quickly changing images such as a camera image.
What happens if you try to import the ActiveX on a project with a PC RT ?
Hi.
I know this is possibly a double post but I'm trying to see if I can stir up oldposts becuase maybe somebody got the active X working but did not put the fact back up here.
I get the following error when trying to use the lastest ActiveX from Cognex in a WinCC Flex project for a PC577b
I have worked on this problem for the last couple of months and have not been able to get it to work. I am using OPC to get info from the camera and have setup an FTP server on the PC to get the images. This works but not as good as the Active X control would be.
Could it be possible that the Active X control didn't get registered somehow on the PC. I believe they won't work if they aren't registered.
If it isnt registered, then you cannot add it to the "my controls" dialog in Flex ES in the configuration PC.
I think spawn_e_git has gotten past that bit.
Yes it is registered and shown in my controls.
I installed the latest version of Insight Explorer (V4.4.1) and the new active x was automatically registered in the WinCC toolbox.
Charles.
Can you give me some advice on how to set up the FTP server?
I do FTP the imgae across which can be viewed with a browser but with the version of camera I am using only the imaage is shown and not the reference graphics that are shown when using insight explorer.
This is a major PIA and may well make my company throw WinCC Flex in the trash and use a VB or .Net project for the HMI control.
Kindest regards
I got some help from here.
http://www.mvresource.com/index.php
Do a search over there and you will find a couple post on FTP setup. You can also use insight as an FTP server. The problem with this is Insight must be open. Cognex has a "how to" on how to do this on their web site. You can google cognex ftp server and it should show up.
I did make a little step by step for setting up the ftp server however the pdf is to large to post. If you send me a pm with your email I will send you a copy on Monday.
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,056
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
9,000
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,632
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,133
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,407
