WinCC Flex Switch Object and Multiple HMIs
Galaniz
Feb 2012
Corpus Christi
34
I have two questions regarding the "simple object" switch in WinCC Flexible:
1. Does the switch object act as an input and output?
I have running some tests to anwswer this question with PLC Sim and the runtime on my PC. In the test, I am able to change the state of the switch on the HMI by changing the value of the tag is PLCsim. This would indicate that the switch acts an input/output. However, I read else where on Siemens website, that PLCsim will overwrite the value in the HMI, so I don't know if this is just a function of PLC Sim or if this will actually work this way with a real PLC and HMI.
2. Will there be conflict if I am running two identical HMIs controlling the indentical switch object?
This is related to question 1 in that if the switch works as an input/output rather than an output I suspect I will not have a problem, but it switch acts only as an output and one is high and one is low, then I could see some unpredictable things hapnning.
Thank you very much.
Gabe
Does anyone have any experience with these. I'm trying to set this up and having issues with it. I am trying to a trend to monitor inputs but they...
4,922
Hi Guys, I currently run Protool Integrated with Step 7, and have read on this forum that if Wincc Flex is installed on a pc with Protool that...
4,412
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,064
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
9,007
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,635
