WinCC Flex & WinCC 6.2 Questions
smcmanus
Jan 2006
Vancouver
109
1.)Is WinCC Flex 2005 just newer software then WinCC 6.2?
2.)I have a new machine. It’s been done in WinCC 6.2. Unfortunately I have only WinCC Flex Advanced. Can I open it with Flex Advanced and make changes and save it back as WinCC 6.2?
3.)If I am able to open it and make changes can I save it as a WinnCC Flex Advanced project and run it on the same SIMATIC Panel that the 6.2 was running on?
4.) How do I add or remove HMI from SIMATIC Manager?
Appreciate your responses
Is it possible to download WinCC 6.2 and run the trial period? I just need to see if my application will work or even open. Looked on the Siemens website but cannot find anything. Are there any other web sites?
There is a migrate function in WinCC Flexible to import WinCC projects. But it will only import partially, and you cannor export back to WinCC. WinCC Flexible should be the successor to WinCC, but it appears that the release of WinCC Flexible with WinCC functionality is slipping. Now the release has slipped to at least 2008.
If the "panel" runs a WinCC project, then it must be a panel PC. You need WinCC Felxible Advanced to create a PC runtime project, and a WinCC Flexible runtime license to run the project on the PC.
To add: In Simatic Manager, select the entire project (place the cursor at the root of the project tree) then use the "insert" function and select a "HMI" or "PC Station". The latter is used for PCs that may contain a HMI and possibly other components such as OPC servers or the WinAC soft PLC.
To remove, just select the HMI component and hit delete.
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,067
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
9,014
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,636
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,139
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,408
