WinCC Flexible 2008 Alarm Triggers
wlong995
May 2008
Michigan
I am new to WinCC (and Siemens in general). I am setting up alarm messages for the HMI, and I cannot get them to display the way I would like.
There are 56 possible failures over 5 different stations. If a part is rejected, I need to display what failed, and where. The DB is all set up with the proper messages, and I can get them to display on the HMI. But...here's the problem. The customer want's a fail to be "0" and a pass to be "1" so if we lose information somewhere for whatever reason, we assume a fail rather than a pass. In doing so, When I turn on a bit to give a pass, it turns on the alarm message saying it failed. I have searched for days, and I can't find a way to change the state that triggers the alarm messages. Is it possible to trigger an alarm when a bit is off?
Can you just put a 'not' instruction in front of the logic that triggers each alarm bit?
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
298
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
116
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,487
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,318
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,865
