WinCC Flexible 2008 problem
inst_tech
Jan 2010
Scotland
58
Hi Folks,
Wondering if anyone can help me..... I've just installed an MP277 Touch and everyting appears to work apart from one major problem! I've created an alarm page where all the alarms display correctly and can be acknowledged but when a new alarm comes in a large DOS (if you see what i mean!) type screen appears right in the centre and stays there until I can acknowledge the alarm.
I'm wondering if there is a checkboxed ticked or if this is something to do with the fact the whole project was imported from an old OP27 screen then modified to suit?
Any help greatly appreciated.
Inst_tech
The alarm view can be found in the template, and you have to activate layer 1, 2 or 3 to see it (dont remember which of these layers it is).
When you remove the alarm view, you should think about how you tell the operator that an alarm has activated. The alarm page you have created will not always be active.
Thanks Jesper.
I've had a look at the configured alarm view and it says that its layer 0. However on the template layer 0 is highlighted in red and can not be deselected. Any thoughts?
Cheers
inst_tech
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
285
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
114
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,483
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,299
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,859
