Wincc Flexible op 7-dp
duckie112
Mar 2012
In a cardboard box
46
Hi I have a problem with wincc flexible. I want to use a op 7 -DP module with the product number 607-1jc20-0ax1 but can't find it in the hardware configuration. Is a install needed for this 1 or does it use some other device in the hardware like the op77? If anyone can answer this question it would be wonderful, I couldnt find anything on internet.
EDIT: I also have a problem with a Master/Slave setup. I use CPU313C-2DP as master and CPU315-2DP as a slave and theyre connecting with each other with a profibus cable. The software for it that I used is from http://support.automation.siemens.c...=cseus&aktprim=0&extranet=standard&viewreg=WW
My only problem is that I cant seem to get the outputs high in the variable table and also the inputs wont show on the variable table as on when I switch them on (sm374 card on slave). So far I don't see anything wrong in my software and setup and used this example.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
304
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
118
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
765
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,606
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,488
