WinCC PC-PLC cross-subnet communication configuration in TIA
aamirawan91
Feb 2024
Karachi
32
In our production plant we have multiple different networks (subnets). IT dept have setup routing between them so different subnets can communicate. When I connect my laptop to Network A and let it automatically assign me an IP address and hit ipconfig in cmd i get the following details
IPv4: 172.16.102.58
Subnet Mask: 255.255.255.0
Default gateway: 172.16.102.254
When I connect my laptop to Network B and let it automatically assign me an IP address and hit ipconfig in cmd i get the following details:
IPv4: 172.16.103.95
Default gateway: 172.16.103.254
It means they are both in different subnet but If i ping a computer from network A to B i get the reply which means IT has setup routing between them therefore they can communicate.
Now, If i want to connect a PLC S7-1200 in network A and a Wincc Advanced or Unified PC in netwok B how can i make them communicate with each across these two different subnets? And what should be the IP configurations for the PLC and the WinCC in TIA Portal? I think I will have to use the "Use router" option but not sure which router address will be put in there. From what I understand i think the configuration should be like the following:
For PLC which is in network A:
IP: 172.16.102.x
Router Address: 172.16.102.254 (after checking the "Use Router" option)
For PC which is in network B:
IP: 172.16.103.x
Router Address: 172.16.103.254 (after checking the "Use Router" option)
Please check the configurations. Is this ok? If not then what is the procedure? Please guide as networking is something I am not good at.
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
87
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
145
Hello, someone have experience about how to delete an alarm message(alarm already solved) from alarm viewer with something coming from PLC? THANKS
387
Hi everybody. Please help me. i want to know is it poosible to write SCADA program for a CJ2M-CPU31 OMRON PLC in WINCC program? Programming of...
1,408
Hi, So we have 3 pc with wincc rt installed. I have the program in my laptop and downloaded to file system the scada file, transferred it to the...
2,033
