WinCC professional multiplexing
zerocrash
Feb 2010
aaa
Hi all,
I’m programming 4 PLC`s which in total are controlling 18 identical machines. The visualization of these machines are programmed in WinCC Professional.
With WinCC advanced there was the option to multiplex tags by using an textlist with all the different tags, and as control tag an index value which represented an machine number.
Is there an alternative method to set this up in WinCC professional?
I can use a script to do this, but maybe there is another way? Indirect addressing is also a possibility, I know you can do that in one PLC between different DB’s, but if I remember correct, indirect addressing between PLC’s is not possible.
PLC’s are Siemens 1500 series. Does anyone have a good suggestion to tackle this problem?
Thanks in advance.
Hello to everyone, I need to comunicate With a Modbus gateway(TCP-RTU)connected throught Modbus TCP/Ip on wincc v7.5 or professional; i will...
270
Hello Everyone, I have PLC programmed in TIA 16 and this is in Engineering PC. And other PC station have Wincc RT professional V14 sp1. I want to...
2,188
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,268
Hi, I am logging tags every 24Hr in table view in siemens WinCC RT Professional. Every day at 7:00:03 AM a value is logged. WinCC takes value from...
17
3,605
Hello guys, this is my first post on this forum and i hope u can help me. Im doing a project where we need to read data in the Wincc Professional...
1,052
