WinCC RT Advanced - Data Logging Memory
Mar 2021
Scotland
Hi folks,
I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging. The HMI currently logs 50000 data records for 16 tags at a 2 second interval, which is about 1hr 43mins of trending. They do not want to increase the time interval, however they would like a couple of days of trended data. I can do this by increasing the number of data records, however I read that this can decrease the performance – what I could not find was a quantitative measure on this – i.e. is 50000 data values a lot already or would changing it up to 650000 (approx. 24hrs) make a big difference? I see that there is an estimated memory generated in TIA for the number of data records, however does this take up RAM or SSD...?
System is running: WinCC RT Advanced, V14, on a Simatic HMI Panel PC, Interl Atom E3845, 1.91GHz, 4GB RAM, 128GB SSD Harddrive Windows 7
It’s installed offshore, so cannot really do a trial with it…
The maximum no of records in a log is 500000. Increasing from 50000 to 500000 gives you 17.3 hours.
You can split into multiple logs so for example you only have 4 tags per log. That would give you ~70 hours i.e. 3 days.
Regarding the performance, maybe changing into segmented circular log instead of circular log will reduce the performance penalty.
You can run your WinCC RT Advanced on your PC. Even though it is more powerful than the target it may give you an idea.
Let us hear how it goes.
Hi, I am currently logging the value of some data tags using Historical data lists however when I view them in Excel I get one column with the...
1,664
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
311
Dear all, in wincc advanced RT (same as in wincc flexible), when connection to PLC is loss, output field (real) goes to ####. I suppose that tag...
164
I created a project with Tia portal wincc runtime advanced PC station and also activated its smartserver for some smartclients to connect to it...
343
We are rewriting software for a Simatic PLC/HMI originally made with TIA Portal V16. We will make use of a library that was developed for V17...
1,628
