WinCC scripts activation?!!
Tarek_Ashraf
Mar 2009
cairo
16
hi, im a student and in my project im using wincc flexible 2005...i have a problem in activating the scripts in wincc and make them work properly...attached the scripts i have written and some screens from my wincc project and the error that appears in the script debugger in runtime...these scripts are supposed to read instantaneous voltage and current from an induction m/c through a PLC and calculate the rms and max. values then the phase shift....so could anyone please help me find whats wrong with my project?? waiting for a reply and thanks in advance....
  • SCRIPTS.doc
thats to record an array of instantaneous voltages lets say an array of 10 values and from this array i can calculate the RMS value....and also from this record i can compare between the instantaneous readings to know which value is the maximum one using SQL....
The error message in the forpost.jpg picture tells you that the DNS is missing.
You have to setup a DNS with the name from the script. In the scripts there are two connections to MSDASQL with the DNS names "voltage" and "currnt".
If you are new to ODBC, then you should study how to setup this first.
thank you very much jesper....i think i must read something about ODBC..but you put me on the right way to start...:D....if you think you can tell me anything that would be helpful to me....i'd be very thankful...
If you google for "ODBC forum" or "ODBC tutorial" or "learning ODBC" you will get a lot of helpful links.
This one is a brief example on how to setup a DNS:
http://www.chrishardy.co.uk/asp/tutorials/odbc-dsn.asp
Notice, there must also be an active SQL server of some kind somewhere.
Depending on the type, you must select the matching ODBC driver in the DNS configuration.
hello, i need these files down here, DBExt-DLL (realizes database connections of WinCC-Skripting) MessageStatistic-DLL (status message...
1,029
Hey guys, I am trying to write a vb script in wincc 2007 flexible. Basically I need to have a button which is on my overview on every screen...
1,626
Hi Everyone, One of the projects we have has a very large number of scripts that require translating. It would be great if we could export the...
1,889
Hello, I am using WinCC Flexible and want to test a script with the runtime simulator. Does anyone know if the scripts will run in the...
8,774
Hi, I hope someone can help me with this. I have managed, using scripts, to export data in a .csv file. The problem I have is that when I open...
2,483
