WinCC tag scaling
Dick G.
May 2004
I'm trying to scale an analog variable tag that is used as an output to two valves. The valves are set up for "split-range" operation. One valves opens on a signal of 19200-6400. The other opens on a 19200-32000 signal. The output is a 20% offset (4-20ma) so the binary is equal to 6400-32000.
I have two tags defined in WinCC, one for each valve. I'm using the Linear Scaling function in the tag properties to display a 0-100% range so I show the respective valves position on a screen.
The scaling looks like this for the two valves:
Valve1 - 6400-19200 = 100-0
Valve2 - 19200-32000 = 0-100
When the tags display in run-time one or the other tag will "gray out" depending on the binary value of the PLCs analog output.
What am I doing wrong? Should I be doing some sort of math in a "C" or "VBA" function? Any help would be greatly appreciated!
Thanks.
Recently I work on a project where my customer has WinCC as HMI, and Siemens batch as backend, and they use APL as the interface for CM and EPH...
449
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
420
In some screens, the tags are not 'updated'. If then i look into the Tagmamangement: the values and quality codes are "???" (See picture in...
600
Hello Everyone, Can somebody tell me how I can move a internal value ( word, int, float etc) to a external tag in C script or VBS or another...
2,022
Hello, I am using WinCC Flex 2005 and I want to configure a button. If you look at the picture below, on release of the button(which is named...
1,398
