WinCC VBS
Apr 2003
Belgium
434
Hello everybody,
I'm facing at the moment a small problem with VBS. I'm writing data from WinCC towards a SQL Server, that part works but with retrieving this data I got a problem.
I send a date to a Table in an SQL Server
WinCC (datatype) Tex tag 8 bit character set
SQL (datatype) Smalldatetime
For the code see below
strSQL = "INSERT IGNORE INTO BHI_Measuring_Station (Production_Date) Values ('" & Int(CDate(V15)) &"');"
This part works, now I would like to retrieve this data and I use the following code.
V1 = HMIRuntime.Tags("Balenumber_man").Read
Dim objConnection
Dim strConnectionString
Dim strSQL
Dim objCommand
Dim rsData
strConnectionString = "Provider=MSDASQL;DSN=CLaSS_Production;UID=sa;PWD=siemens;database=CLaSS"
strSQL = "Select Production_Date from BHI_Measuring_Station where Balenumber = '" & V1 & "';"
Set objConnection = CreateObject("ADODB.Connection")
objConnection.ConnectionString = strConnectionString
objConnection.Open
Set rsData = CreateObject("ADODB.Recordset")
rsData.Open strSQL,objConnection
If Not rsData.EOF Then
rsData.MoveFirst
V3 = rsData.Fields(0).Value
MsgBox (V3)
Else
MsgBox("Baalnummer bestaat nog niet")
V3 = ""
End If
MsgBox ("OK1") 'HMIRuntime.Tags("Production_Date"))
HMIRuntime.Tags("Production_Date").Write V3
MsgBox (V3) 'HMIRuntime.Tags("Production_Date"))
objConnection.Close
rsData.close
Set objConnection = Nothing
Set rsData = Nothing
MsgBox ("OK3") 'HMIRuntime.Tags("Production_Date"))
End Sub
The Producion_Date is red and U can see it in V3 but it doesn't show anything in HMIRuntime.Tags("Production_Date")
Is there something wrong with
Anyone?
Hello, I just started learning WinCC V8.0 3 days ago, so I'm still new to how everything works in this program. I've created a pop-up with a...
693
Hello everyone. I'm trying to export data to excel from Wincc. My code is global action that executed every second that create excel filer per...
5,740
Hello all, I have written a VBS script to read a group of tags, and put the values and tag name etc into a text file when I press a button on one...
1,880
Hi, In my Plant i have PCS7 (WinCC V6.0+SP4) System.( one ES/OS and One OS )... I need Shift Report (every 8 Hours ) using VBS script or Default...
2,247
Hi I am trying to vary the number of decimal places via a script (MP377) Dim obj Set obj =...
1,312
