Windows 10 Rslogix 5000 errors again
showshocka
Mar 2011
USA
510
Hi. Yesterday my Rslogix5000 20.03.00 just stopped working. I reinstalled it as an Administrator, nothing. I also reinstalled it using compatibility windows 7 and 8, nothing. Same error. Does anyone have any suggestions on this? Thanks
Strong possibility of a recent windows update. There are several related to spectre and meltdown that train wrecked some Rockwell software. There are KB articles about it if you search around.
Just yesterday I had a fatal error come up on my Windows 10 HP running RsLogix5000 20.01. First time I installed it on my machine and it logged a fatal error .dmp file. I called rockwell support and they said you CAN NOT run anything less than 20.04 on a windows 10 machine. I am running a x64bit system. If you have Rockwell Support give them a call. They sent me the link while I was on the phone with them. If you do not have support I can not imagine that it would be an issue that I sent you the link if needed.
EDIT: I just saw your screenshots and the fatal error code was identical to the one I received. Donwload 20.04 and it will fix it.
Before double-clicking your program to open it, hold ctrl+shift and then double-click the program. I forgot what it does, but I had a file where everything was greyed out and I could not click anything. Ctrl+Shift trick fixed that issue.
Hi guys, I am trying to install Logix 5000 ver 19.01 on windows 10. Are there any tips for the installation? TIA
6,555
V19 does not run on my Windows 10 laptop, I tried everything - run as administrator - compatibility Vista, 7, XP - reinstall .net framework Has...
5,293
Im running windows 7 on vm and studio 5000 is version 27. I opened a clients file this morning to add expansion i/o and drives and as i was adding...
1,430
Hi all, Status update for posterity, and also request for help! I have spent the day installing as much RA software as possible on Windows...
16,028
Hey guys, The local district bought their own laptop so they can have all of their PLC programs on it and have a mobile laptop that can go around...
16,850
