Winn911 and factorytalk view SE
PhilPLc
Dec 2019
usa
Is it possible to disable winn911 from sending out alarms (calls and messages) with a button on factorytalk SE screen?
You can put it into an Inactive or Active state with a .bat file (Active and Inactive .bat files are in the Win911 install directory) from the machine on which Win911 runs.
Simply run the following on a button press:
Run C:\Program Files (x86)\WIN-911 Software\WIN-911 Enterprise\Standby Activate\Activate.exe.
or
Run C:\Program Files (x86)\WIN-911 Software\WIN-911 Enterprise\Standby Activate\Standby.exe
If you want to do this on a distributed system from any client, then it becomes much more complicated as you have to navigate through windows security. I tried and tried to get this to work but it was ultimately defeated.
In the end we left it as a server only function on a recent system, which was fine as only anyone with any authority would be working on the server and only operators on the clients.
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
43
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
222
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
111
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
152
