WINtelligent VIEW questions
sparkytex
Jun 2013
Port Hardy B.C.
354
I have a problem with an Amp readout from one of our secondary treatment blowers on the Winview HMI. I've never used winview to search for plc address's before, only Wonderware. What i normally do on wonderware is double-click on the readout icon in window maker i want to look at and find which plc and address the Tag is from, then search the plc to see whats happening. How in the hell do i do this in WINtelligent View??
so i figured out how to find which address and PLC the "tag" is from, simply by double lcicking.....DUHHH!!!
we have 4 blowers for our secondary treatment which any one blower can be running at a time and others shut off. Each blower has its own amp readout on the Wintelligent View and also theres a total amperage readout for all 4 blowers. What I didnt realize is Winview is set up to do the scaling in the program, the PLC does not scale the data. I find this a bit odd, why not use the PLC to scale then just send the data to Winview. The total amperage readout is set up in Winview to ADD all 4 blower amperages together using the scaling formula on Winview. Problem with this is if any other of the blowers is reading 0 then it screws the whole formula by actusally subtracting off the other blowers. I dont know who set this up but its a really strange way of doing things. here's the formula
p: Air-1, F8:4, (blower1)
Q: Air-2, F8:4, (blower2)
R: Air-3, F8:4, (blower3)
S: Air-4, F8:4, (blower4)
actual formula as shown on winvew
(P-4)*30.86+(Q-4)*30.86+(R-4)*30.86+(S-4)*30.86 - This would only work if all 4 blowers were online and the
data coming into the F8:4 address's were above zero would
it not??!!
right now the total amperage readout is in the minus because only one blower is online and reading 262 amps. The question/problem was why is it in the minus.
We have an old punch press machine. Many years ago (probably around 1990) a machine builder called Steelcase Inc (currently not in machinebuilder...
1,578
Hello, I'm working on a HMI upgrade project. It's from Rockwell Wintelligent View to PanelView Plus. I was wondering someone can help me to get a...
2,428
Figured I throw this out there we have support from Rockwell for an old piece of software Wintelligent Recipe came on floppies ;) anyway the PC...
1,630
Hi all, I'm looking for an old "WINtelligent Linx ver 5.0.4" software, does anyone have it ? Thanks regards
5,380
Can anybody help me with Wintelligent Linx? the question is here: http://www.plctalk.net/qanda/showthread.php?t=13492&highlight=wintelligent+linx...
2,052
