wire color again
awalinski
Sep 2002
38
Does anyone know what the wiring color code is for Caribean?
We have to build a panel for 208V 1 phase, and some say it should be 2 Black wires ( 2 hot wires), some say Black - line and White - neutral. This is an ongoing question and it arises every time we sell a project into this region. Do we treat them as we would US customer or European?
Not being one that has the faintest idea, I'm wondering why not send them what you've sent them in the past that hasn't been sent back or rewired. Surely your engineering dept. (you?) should be able to find the right authorities to answer local questions, or at the very least a local inspector. How 'bout this...if they speak English, go with US standards. If they speak French, go with European standards. Sorry no concrete ideas but you do pose an interesting question. Would like to see the 'real' answer you get. Good luck on this one.
Bob
Dumb question, Hooking up two wire reed switches out in the field. They are wired into sinking input cards. Once the wires leave the panel, do...
1,506
We are creating a CE compliant version of one of our products, for sale in Ireland and the UK. We would like to use Brown for VDC+ and Blue for...
3,975
Good Morning , I'm building a control panel with PowerFlex 525 drives. I have black wire for the 480 vac , red for 110 vac , blue for 24 vdc...
2,912
Hi! I'm going to build a cabinet for US in IEC standard but we change the colors to the customer demand. It's supplied with 3x480VAC and I use a...
29
6,148
What is the US standard color coding of the high leg and other phases in a delta circuit? TIA This is what I have:
3,523
