Wireless 2D Barcode Reader Needed
David Bennett
Jun 2003
Rinco, Ga
21
Hi all,
I need some recommendations on a really good wireless 2D barcode reader.
I have done several projects with fixed units but this one requires a wireless hand held unit. Industrial grade type, preferrably with the ability to verify or even manually enter a barcode before transmitttal to the database.
Thanks,
David
Thanks for the info
Thanks panic mode,
The 3400 series looks promising.
How well is it working for you and does it hold up well in the factory enviroment? Are there any setup issues to be aware of?
I just looked at the phaser series but, it doesn't do data matrix, at least according to the documented info.
AML's M7100 also looks promising but I want some user recommendations and feedback on it before I place my companies reputation on it.
Again, thanks. :)
David
Hello, I want to establish the communication between Controllogix plc (2756-L62) to wireless Barcode scanner (MT2090) through prosoft...
5,860
We sometimes have problems with our component suppliers barcode labels, the issue is that the info contained within the barcode does not match the...
8,692
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,379
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,050
Hi All, I am working with an outside vendor on a project, and they have asked if they can use Wireless IO link for one of their remote IO blocks...
1,139
